Author: Subject: Did sierras have a ballast resistor?
flak monkey
posted on 26/4/06 at 01:33 PM Reply With Quote
Simple question for those in the know...
My mk 2 escort loom has a ballast resistor in it. Were the sierras fitted with a ballast resistor?
If not I need to chop out the ballast resistor from my loom as the solenoid on the sierra will not have the facility to provide 12v starting voltage to the coil.
Sera
http://www.motosera.com
muzchap
posted on 26/4/06 at 02:07 PM Reply With Quote
My late 'H' reg Sierra didnt... I'm sure of it - because I was always worried about them after my MK2 Fiesta one kept cracking
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Schrodinger
posted on 26/4/06 at 03:49 PM Reply With Quote
My understanding was that it was the later engines that had a balast resistor and I would have thought that the Sierra was after the Mk2 Escort.
I'm sure that there is something on Burton's website/catalogue regarding how you can tell.
posted on 26/4/06 at 05:55 PM Reply With Quote
Take a 12v from the solenoid cranking feed to the coil if you want a 12v boost for cold starts.
