Author: Subject: shielded cable.
Danozeman
posted on 27/4/06 at 10:32 AM Reply With Quote
shielded cable.
Wheres the best place to buy shielded cable from??
Maplins???
Dan
flak monkey
posted on 27/4/06 at 10:35 AM Reply With Quote
What sort?
Most audio cables are sheilded (stuff used for phono wires is good). You can get that from Maplins for next to nothing.
Sera
http://www.motosera.com
dave1888
posted on 27/4/06 at 10:53 AM Reply With Quote
I got some from maplins i think it was 90p a metre two core shielded stuff for my megajolt.
nludkin
posted on 27/4/06 at 11:35 AM Reply With Quote
You could also try RS at rswww.com. If you sign up online you don't have to be a business to purchase from them.
Julian B
posted on 27/4/06 at 12:05 PM Reply With Quote
If your after sheilded cable to send data down , you hasd best get the right stuff. The environment under the bonnet of most cars is extreemly harsh ( electronically speaking ) and any stray RF from the ignition system will completly distroy any data streams.
RS do shielded cable for rs232/485 but it is very expensive and i dont think its got the thermal capability either.
Try to find out what the data rate is , if it is data, and post back because if you only want a couple of meters i might have some gash at work you can have
Danozeman
posted on 27/4/06 at 12:06 PM Reply With Quote
Its for the CRank sensor for my magajolt. Ill try the audio stuff and see what happens.
Dan
graememk
posted on 27/4/06 at 01:07 PM Reply With Quote
got mine from a £1 shop, stripped a cheap mic.
muzchap
posted on 27/4/06 at 02:29 PM Reply With Quote
You want shielded twisted pair
It's an AUDIO cable used for PA systems - I'm hoping it'll be good enough for my Speedo measurement
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Danozeman
posted on 28/4/06 at 06:07 AM Reply With Quote
I have found some shieled cable at work. So cheap as chips if it works
Dan
zetec
posted on 29/4/06 at 05:44 AM Reply With Quote
I used just normal unshielded and it works fine so don't worry too much.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
