rusty
| posted on 29/4/06 at 09:42 PM |
Speed Sender (VSS)
Hello
I have a type 9 box and machanical speedo but my ecu needs a VSS input or it logs a fault and puts the check engine light on.
Does anyone know of an inline speed sender that will fit in line on a type 9 gearbox speedo cable.
tks
| posted on 29/4/06 at 09:58 PM |
Wich ECU?
Wy do you use a macanical one??
Do you know how the original one works?
Which signal requires the ECU??
Tks
Chippy
| posted on 29/4/06 at 11:02 PM |
The Ford 2.9i XR4 x4 has a VSS in the speedo cable, which you could include in yours. There is also another Ford, cant remember which one, that has a
VSS fixed at the end of the speedo cable near the bulkhead. Hope that helps. atb Chippy
Fatgadget
| posted on 30/4/06 at 01:13 AM |
Brantz do an inline one that fits any cable.
[Edited on 30/4/06 by Fatgadget]
James
| posted on 30/4/06 at 04:09 PM |
My Dad's 2WD, 'E' reg, 2.9i Granada, had one. Had Type 9 manual gearbox.
HTH,
James
- Muhammad Ali
davidwag
| posted on 30/4/06 at 05:56 PM |
Most FWD fords have a VSS that just screws on the end of the speedo cable between cable and gearbox. I'm pretty shore it should be the same
thread as type 9 gearbox.
rusty
| posted on 1/5/06 at 09:20 AM |
Thnks for the help guys. The engine is a toyota 4AGE which originaly had the VSS in the speedo.
Look like a hunt down the scrapy should sort me out now I know which cars to look on.
rusty
| posted on 1/5/06 at 09:28 AM |
Just looked on Brantz web site and I see they also do one for a ford gearbox does anyone know if this will fit a type 9 it says it han an M18 thred.
| posted on 1/5/06 at 03:35 PM |
Can't help with the Brantz item but the FWD Ford unit that screws on will not fit as the type nine speedo cable is held in with a circlip . Late
manual Granadas have a VSS ,not sure if you will have enough clearance between box and chassis though
