Author: Subject: gear shift lights
omega0684
posted on 1/5/06 at 11:40 PM Reply With Quote
gear shift lights
anybody used one of these or heard of any opinions....
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=6_7&products_id=39
PAUL FISHER
posted on 2/5/06 at 12:01 AM Reply With Quote
Ive got the omex,sequential system fitted to my,Indy blade,works great,but sometimes can be difficult to see in direct sunlight,looks great at night though
omega0684
posted on 2/5/06 at 12:07 AM Reply With Quote
how exactly do they work then, im running a type 9 box, would it be worth getting one
greggors84
posted on 2/5/06 at 12:13 AM Reply With Quote
Work off the ignition pulse, so off the dizzy or ECU depending what you have. (Dizzy most likely if you have a pinto)
You just set it at what revs you want to change at, im guessing by reving to that amount then pressing a button.
Always see the omex ones on ebay. Missed out on one a while back.
Chris
The Magnificent 7!
PAUL FISHER
posted on 2/5/06 at 12:35 AM Reply With Quote
Yes,as Chris says,they pick up a pulse of the ecu,easy to fit,the sequential ones light up each light at a set RPM,for example,on mine,10250,10750,11250,11750.
posted on 2/5/06 at 07:16 AM Reply With Quote
I use the cheaper one that's just a rev limiter. Works well, easy to fit and wire in, fairly simple to program up.
