irvined
| posted on 3/5/06 at 10:16 PM |
Hazards and Main Beam
Hello
Managed to do something silly to my wiring, everything was working fine, then today for reasons I can't find, the hazards stopped working, along
with the 'flash' for the high beams.
I suspect since both of these used to work with the ignition off, they both run off the same feed.
I have a premier loom, could anybody with a wiring diagram tell me what colour wires are likely to be wonky?
http://irvined.blogspot.com
Tigger
| posted on 4/5/06 at 12:18 AM |
David,
My first port of call would be Alan at Premier, he knows his stuff and is always happy to help whenever I've called him
as far as I can remember,
Hazard's are fed by Green(Ign Live) and Purple (Perm Live)
High Beam is fed by a Blue wire from the light switch
Tigger
[Edited on 4/5/06 by Tigger]
| posted on 4/5/06 at 06:54 AM |
If they both use the same earth and it hasn't blown the main fuse it'll be this.
irvined
| posted on 4/5/06 at 01:49 PM |
Mwhahahah! well it turns out it was the beedin' stalks, spent the morning manically scratching my head, checking connections and checking them
again, then again just to make sure i wasnt being a thicko, everything should have been ok.
Decided problem had to be with the stalks, removed them, stripped them and they were minging, full of green yuck, scraped it away, nearly worked, ie,
it kinda half blinked, one trip to the scrap yard later and my hazards work again.
Blood pressure down a few psi
Oh, and the sierra stalks arent the easiest bits to get back together again, the trick is, don't open them in the first place.
