Author: Subject: R1 Battery, Generator
nitram38
posted on 14/5/06 at 03:55 PM Reply With Quote
When using the R1 engine, do you use a different battery and generator/alternator setup to power the extra load from the car electrics, or does it cope without any changes?
fesycresy
posted on 14/5/06 at 04:01 PM Reply With Quote
Just use the R1 set up, should be fine.
nitram38
posted on 14/5/06 at 04:04 PM Reply With Quote
Cheers, even better..........locost solution
skydivepaul
posted on 14/5/06 at 05:09 PM Reply With Quote
I use the R1 set up with no problem. never need to charge the battery even though i hardly use the car
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
posted on 15/5/06 at 09:40 AM Reply With Quote
hey skydivepaul - I loke the side panels thinkgy - looks like an glass widow with a fire extinguisher inside
