Author: Subject: nahhh
tks
posted on 24/5/06 at 08:42 PM Reply With Quote
nahhh
its just that i want to keep it simple
and don't want another led / resistor combination to wire it up.
also drilling and making it multi colour isn't what i like (atleast for now)..
i make 2 power sources 5volts..
one is directly connected to the led with a resistor. when you switch your lights on then the regulator will be 12volt powered,
because of the 5volts and the resistor the led will light up very light.
When i use the button, i will use a normal 5volts... wich isn't limited then the led will fully light up.
When i have got it finished i will show it.
in fact it just a dimmer wich i create...
Tks
posted on 6/6/06 at 02:44 PM Reply With Quote
