Author: Subject: regulator mounting
dilley
posted on 15/6/06 at 01:53 PM Reply With Quote
regulator mounting
Having moved all of my loom in to the dash I need to mount the regulator, does it have to be mounted on ally for heat dispersion??
posted on 16/6/06 at 09:04 AM Reply With Quote
well I don't know what regulator you are talking about but it depends on the power going through it.
For example Land Rover voltage regulator, small metal box, used on myany other British cars, sits on back of speedo in free air.
If the regulator has a metal tab, that would normally impley it likes to sit on metal to transfer heat away.
One thing to be aware of is does the tab need to be insulated from the metal; usually the tab is ground.
Any idea what is powered by it (lamps/instruments etc
Sorry, without knowing exact details, can't advise but connect it in free air, hold it, turn on and see how hot it gets, if you cannot hold it in your hand, then heatsink is required.
dilley
posted on 16/6/06 at 10:42 AM Reply With Quote
sorry for lack of info, its the regulator/rectifier for alternator on my blackbird
posted on 17/6/06 at 12:55 PM Reply With Quote
mine is just cable tied to a convinient chassis tube, away from the exhaust but hanging free. Worked well for a few months and a trackday now.
