chrisf
| posted on 21/6/06 at 05:09 PM |
Fuel pump hop
I wired up day time running lights on my car--wired directly to the ignition-side fuseblock. I need to wire the rear tailights. Does anyone see an
issue with the fuel pump and the rear tailights using the same feed?
--Thanks, Chris
Snuggs
| posted on 21/6/06 at 05:33 PM |
You could try it but the rear lights may flicker due to the pulses of the pump.
They did on mine when I needed to by-pass the immobiliser.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
chrisf
| posted on 23/6/06 at 05:25 PM |
Clive:
Thanks for the reply. I'm just using a little carbed bike fuel pump. Do they draw enough current to make the lights flicker? My tailights are
only two bulbs...
--Chris
