davrus
| posted on 23/8/06 at 10:03 PM |
Brake fluid sensor
Greetings
Just a quick question , do you have to have a low brake fluid light on dash for s.v.a .
RazMan
| posted on 23/8/06 at 10:15 PM |
The quick answer is yes
Raz
Dusty
| posted on 23/8/06 at 10:29 PM |
And a means of testing the light from the drivers seat, usualy a handbrake switch linked to the same circuit although it can be just a dash mounted
switch.
cryoman1965
| posted on 23/8/06 at 10:35 PM |
My sva inspector wanted the warning light to work when,
1.He pressed the test button on the master cylinder filler cap.
2. Applied the handbrake. (This was to be able to see the system worked from within the car.)???
My hand brake switch was faulty. FAIL
Cheers Nige
Damn too slow
[Edited on 23/8/06 by cryoman1965]
davrus
| posted on 24/8/06 at 06:28 PM |
does the light have to be marked so mr sva man knows what it is for or as long as a light lights up when he tests it then will it be o k
RazMan
| posted on 24/8/06 at 08:16 PM |
It needs to be the correct 'brake' symbol I believe.
Raz
| posted on 24/8/06 at 11:41 PM |
It has to have the (!) type symbol and be testable from the drivers seat, not necessarily by the handbrake.
