jabbahutt
posted on 12/9/06 at 06:11 PM |
dizzy with points
Hi
I've read the threads and must admit to being more confused than ever so hopefully someone can help.
I'm fitting a 2.0 litre pinto with the injection system ditched and a points dizzy fitted. I take it it's points as there is only a
single fly lead from the dizzy with a plug connector on it (to the coil?) On the side is what looks like a capacitor with a lead going into the dizzy
and inside it looks a bit like an old watch?. The car has a vicki green loom
Question time, as it's a points dizzy I take it I don't need an amplifier as mentioned on numerous threads, just a coil and dizzy?
If that's right does the vicki green loom have a ballast resistor or will I fit a 12V coil.
If that's right what type of coil as I'll probably end up making myself sound like a right idiot talking to the motor factors, is there
more than one type of 12v coil for a points based pinto and if so which type do I need?
thanks for any help you can give and if you can keep your answers in lay mans terms I'd be grateful as you can probably guess I haven't a
clue.
caber
| posted on 12/9/06 at 06:48 PM |
Junk the points! Get either an Aldon Ignitor and their coil or a standard 12V coil from a motor factors easy to set up no points grief and not too
expensive in the region of £80. Or se if you can pick up a secondhand Luminition set up, again use a standard coil 12V.
Points will be a PIA in the long run and if you start messing with compression ratios and things a good powerful spark is necessary to get you going
quickly.
It is also possible to pick up the later electronic dizzy for the Pinto on here or on ebay this is good if you get the whole lit with amp and coil you
can possibly swop with someone who is doing a megajolt set up as they only need the dizzy to drive the oil pump.
Good luck
Caber
pajsh
| posted on 12/9/06 at 06:57 PM |
Why not just go megajolt straight away?
I used to be apathetic but now I just don't care.
jabbahutt
| posted on 12/9/06 at 08:02 PM |
I intend to upgrade in the future but I just need to know if the set up mentioned will work without anything extra
iscmatt
| posted on 12/9/06 at 09:31 PM |
dufus question: what exactly is megajolt?
Dusty
| posted on 12/9/06 at 09:33 PM |
Yes it will. Points dizzy, standard 12v coil not an electronic one, no ballast resistor, ignition live to the + terminal on the coil, - terminal to
the points. - terminal also to rev counter.
Bobs yer uncle and you can stutter about a bit.
| posted on 13/9/06 at 06:52 AM |
Two diiferent types of points dizzie used on these engines - Motortcraft (aka Fomoc/Autolite/Ford) or Bosch.
Important to know which you have as the points gap is very different -- Fomoc is 0.023" to 0.027" and the bosch if I remember correctly
is 0.015" (somebody check this please).
With the Fomoc dizzie always set new points to the top end of the gap tolerance and check after 15 minutes running because they tend to close up as
the heel of the points beds into the cam -- also remember to grease the can very lightly.
[Edited on 13/9/06 by britishtrident]
| posted on 13/9/06 at 09:32 AM |
Fomoco (Ford motor co)
Fomoco were usually black plastic caps and Bosch were brown and the Fomoco is a lot taller if I remember right.
flange nut
| posted on 13/9/06 at 12:29 PM |
The Vicky Green loom doesn't have a ballast resister so make sure you get a standard 12v coil. You can pick them up on Ebay a lot cheaper than
a motor factor.
