craig1410
| posted on 24/9/06 at 11:53 AM |
Spec required for VDO dip tube senders
I'm trying to figure out if a VDO dip tube sender would be suitable for use with an Acewell 3150 type dash unit (100 ohm required).
Does anyone know where I can find technical specs for these senders? I have tried the VDO-Siemens website but it is a typical corporate-waffle type
website with (as far as I can tell) very little substance.
I see that Merlin Motorsport sell these senders in a wide range of lengths and they don't seem too expensive but does anyone know where is the
cheapest place to buy them?
Thanks,
Craig.
the_fbi
| posted on 24/9/06 at 12:56 PM |
Most of the VDO documents are on the website and the choice appears to be 0-90Ohm or 10-180Ohm
Which model dip tube you looking at using?
http://usa.siemensvdo.com/products_solutions/marine/technical-support-documents/senders/Senders-Technical-Support-Documents.htm
craig1410
| posted on 24/9/06 at 02:53 PM |
Thanks for the link but unfortunately it doesn't appears to be the correct type of sender here.
Here is a link to the right type of sender:
http://usa.siemensvdo.com/products_solutions/special-oem-solutions/fuel-measurement/metal-tubular-type-sender/metal-tubular-type-sender.htm
It is referred to as a "Metal Tubular-Type" sender. The resistances may well be similar though but I'd like to be sure. I
can't find any data sheets or tech specs on the tubular type sender.
Craig.
