jabbahutt
posted on 11/10/06 at 06:09 PM |
starter wiring
hello again
starter motor this time, 2.0 pinto using vicki green loom
I get the three large brown wires terminating in one eyelet connector goes on the large stud connection but the wiring diagram says the red and white
wire with a spade connection connects to a male spade on the solenoid and i only have 2 smaller threded studs
one is nearer the engine level with the large stud and the other is at the bottom centrally with a small earth lead connected to it
should i connect it to the small stud that at the mo has no connections?
thanks
omega 24 v6
| posted on 11/10/06 at 06:54 PM |
Sounds like you most probably will have to cut off the spade and crimp on an eyelet. If your ever in doubt about connecting any wire then do it
through a fuse. That way if your instincts are wrong it'll only cost you a fuse.
All info in good faith etc but don't blame me if its wrong.
DIY Si
| posted on 11/10/06 at 06:59 PM |
Doesn't a solenoid need three connections? A +'ve in, a +ve out and a switch connection? They are normally two big posts/connections and a
little spade in the middle for the switch wire.
Sun Tzu, The Art of War
omega 24 v6
| posted on 11/10/06 at 07:01 PM |
I'm reading it as a pre engaged jobbie and the braided wire from the solenoid to the starter motor is not mentioned.
