PeterW
| posted on 20/10/06 at 01:38 PM |
Replacement Ignition for 1.6 Pinto
Quick question...
I've got the standard Bosch ignition on the donor Sierra - its a 1.6 pinto.
Anyone know where I could get a replacement ignition amp, or if its really worth it...??
Peter
mookaloid
| posted on 20/10/06 at 02:02 PM |
if you just want to replace the points then get an Aldon Ignitor.
l
ink £65 plus VAT or you might get one cheaper somewhere else.
You will need a coil for electronic Ignition.
You can use an electronic ignition dizzy and coil off another pinto if you can find one (not the injection dizzy).
Hope that helps
Mark
jos
| posted on 20/10/06 at 02:56 PM |
are you just in need of another or do you want to replace the whole lot.
Ive got a spare coil kicking around somewhere if you need it.
I'm in shropshire BTW
jacko
| posted on 20/10/06 at 03:02 PM |
Hi i bought my dizzy - coil etc fron H&H ignition solutions good price and service give them a ring on
Tel-01384261500
Jacko
| posted on 20/10/06 at 04:05 PM |
For a replacement ignition module try your local motor factors, Partco , Lucas etc. Sierras never had points , think the last Pinto that did was the
Cortina or possibly the Transit
PeterW
| posted on 20/10/06 at 08:30 PM |
l
Hope that helps
Mark
Cheers Mark
Looking at it, its got the Boisch dizzy with the optical set up, feeding the box and coil on the inner wing,
Just wondered if this was a decent system, or whether it could be replaced easily, and with what.
Does the aldon fit straight onto a coil then..?
PEter
mookaloid
| posted on 20/10/06 at 11:00 PM |
l
Hope that helps
Mark
Cheers Mark
PEter
If you can get your system to work then stick with it.
The Aldon Ignitor is only for replacing points.
However if you can't get yours to work then a Bosch points dizzy with the Ignitor replacing the points is a good solution.
Mark
