dilley
| posted on 21/10/06 at 03:54 PM |
oil/water temp sensors
Are they all the same? Im fitting my digidash and the water temperature sensor is a different thread, will the origional one do the same job or will I
get a wrong reading, the same goes for the oil temp,
My current reading when cold and using origional sensors is 16 oil, and 30 water.
Does this seem right?
RazMan
| posted on 21/10/06 at 04:03 PM |
My Evodash needed bosch senders to get the range right and I had to make adaptors to get them to fit, so you may find a similar situation with your
Digidash.
You should be reading ambient on both senders assuming your engine is stone cold so you may have a calibration / range problem
*edit* Just realised that you probably mean oil pressure and ambient is 15psi so more than likely ok.
[Edited on 21-10-06 by RazMan]
Raz
