DaveFJ
| posted on 15/11/06 at 01:56 PM |
starter button etc wiring advice.....
Just sorted out my loom connections to the Sierra ignition switch but.....
Ive Just bought a keypad based alarm/immobiliser and also fancy fitting a start button...
So... any ideas how I could wire it all up so that I had no ignition key and tapping in the key code would enable the ignition so I could then just
press the start button? I know i could have a toggle swith for the ignition but just fancied simplifying it.....
I suppose another question is how I then disable the ignition, perhaps an 'engine stop' button is needed? .....
As you can see a lot more thought is needed and my knowledge of those wiggly amp thingies aint good........
[Edited on 15/11/06 by DaveFJ]
Dave
MattCraneCustoms
| posted on 15/11/06 at 03:37 PM |
Hi dave,
what alarm / immobiliser are you using may I ask, would be interesting to know which to get a bit more info on its wiring. Regards the engine start
button, if you gotta a toggle switch, so you push it to switch the ignition on, and pushed it again to switch off, that would save some hassle. then
it would just be a case of wiring the switch into your ignition feed id have thought
regards
matt
DaveFJ
| posted on 15/11/06 at 03:44 PM |
Not sure on the exact model of alarm yet but it is apparently a Quatum alarm... still awaiting delivery. but it looks like this if anyone can identify
it.....
On second look it seems it may not actually immobilise - it may be 'just' an alarm ah well at least it didn't cost much!
<cue people telling me I have wasted my money! >
Dave
