gingerprince
| posted on 17/11/06 at 03:40 PM |
Headlight Bulbs
My MK currently has pretty dim headlights, looking at them they're 45/40w so I'm not surprised.
I believe the bulb type is p45t asymmetric like these ones: -
http:
//beedspeed.com/bulb-headlight-h4-p45t-asymmetric-duplo-12v-4540w-p-2602.html?cPath=83_175&osCsid=a0c03d8ec09babd2148affb40955c42e
Is there any way I can increase the brightness without swapping the entire lamp units? I'm guessing I have to have that shape of bulb for beams
etc as it'll be matched to the lens/glass etc, so what are my options? I don't seem to be able to see any similar bulbs with a higher
rating.
It's a bike engined car if that makes any difference - could the builder have chosen these ratings because a bike alternator won't support
higher ratings?
Ta, Sy
RazMan
| posted on 17/11/06 at 04:12 PM |
Be careful when increasing the load on the alternator. My old ZZR100 had these bulbs and when I sold it, the buyer uprated them to halogen bulbs and
promptly burned out the alternator (which are very expensive)
Raz
tks
| posted on 17/11/06 at 04:21 PM |
nope
its just the lens used.
search for H4 lenses..
or pirate duplo ones.
Tks
| posted on 17/11/06 at 04:47 PM |
are those bulb halogen type?
I've read that the bowls & lenses are shaped differnt for the 2 types fo bulbs.
you can get more efficient bulbs see
http://www.powerbulbs.co.uk/
now the rating is the same so does that mean they draw the same amps but more light or give out same light but for less amps; the former I suspect.
Make sure that you bulbs are wired as directly to the battery as possible i.e., no poxy switches in between; use a realy;
the headlamp stalk on ladrovers has small contacts that lose you a votl or so (I've measured it) maybe you have something similar; and that
result is less power to bulb = less light.
| posted on 17/11/06 at 06:59 PM |
. Ask your local motor factors for a pair of HB12 bulbs I.I.R.C.
Simon
| posted on 17/11/06 at 08:38 PM |
When I had my FJ1200, the lights on that were pretty crap, so I went to the local bike shop, and got a Zenon bulb.
That was crap too, so I went and got a 120/90w, and stuck a couple of 55w spots on (with main beam).
Night turned to day
Simon
Steve @ sVc
| posted on 9/12/06 at 12:19 PM |
These are ECU bulbs from the 1960s and pre-date the H series bulbs. Rarely seen now, BUT at sVc we have some specialist halogen bulbs with the base
you have, so give me a call on 08 456 581 251.
Regards
Steve @ sVc
