Author: Subject: ford mondeo speed sensor
farmer.palmer
posted on 20/1/07 at 01:25 PM Reply With Quote
Hi there
I have just gotten a speed sensor from a ford mondeo from the scrappers, £2 - bargain!
This has three wires coming from it and i was wondering if anybody knew which wire is which, i.e. +ve, earth, and signal? I am trying to wire this to a VDO speedo...
thanks for any help
james
RazMan
posted on 20/1/07 at 04:41 PM Reply With Quote
I am pretty sure this is right - my notes are a bit sketchy.
Black/brown - +ve
Yellow/brown - Signal
Brown - earth
Best way to check is to use a small 9v battery as a power source and put a multimeter on the signal terminal - you should see pulses as you rotate the shaft.
HTH
[Edited on 20-1-07 by RazMan]
Raz
farmer.palmer
posted on 22/1/07 at 07:53 PM Reply With Quote
perfect - thanks
answer is;
brown - earth
yellow/brown signal
blsck/brown +12v
cheers
james
