Author: Subject: nippon denso alternator
auzziejim
posted on 28/1/07 at 09:08 PM Reply With Quote
right my alternator has decided to stop working, the battery light now wont come on with ignition and the voltage stays at 12v. the alternator has been working and voltage has been at 14v so nice and healthy.
is there any way i can test the alternator and/or recon it? or should i be looking for another?
cheers
james
theconrodkid
posted on 28/1/07 at 09:10 PM Reply With Quote
is the body making a good earth?is the bulb working?
who cares who wins
pass the pork pies
auzziejim
posted on 28/1/07 at 09:12 PM Reply With Quote
tried earthing the body to chassis and still nothing and swapped the light with the working light used for the headlamp tell tale still nothing.
james
Ketchup
posted on 28/1/07 at 09:20 PM Reply With Quote
is the ignition live feed to the alt still good?
theconrodkid
posted on 28/1/07 at 09:24 PM Reply With Quote
earth the alt body to battery earth terminal and see what gives
who cares who wins
pass the pork pies
daviep
posted on 28/1/07 at 10:26 PM Reply With Quote
3 Steps to check charging circuit wiring
Step 1: Check the alternator casing is properly earthed.
Step 2: Check there is a 12v supply comming to the B+ positive terminal (the heavy wire which normally goes to the battery via the starter)
Step 3: Check the charging light circuit by disconnecting the small wire from the alternator (which goes to the lamp) and touching it to the alternator casing or a known good earth, this should cause the charging light to illuminate.
If these 3 points check out ok I would be suspecting an alternator fault.
Regards Davie
[Edited on 28/1/07 by daviep]
davrus
posted on 28/1/07 at 10:29 PM Reply With Quote
Stick a volt meter to the alternator terminal itself. that will bypass the wiring to the battery, obviously make sure it has a good earth!!!
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
