Author: Subject: headlights wiring
locoboy
posted on 14/2/07 at 03:06 PM Reply With Quote
headlights wiring
Im probably getting myself a bit confused again and need setting on the right path!
For my headlights do i run one wire down to the front and split it in a Y and run one to the right and one to the left..............
Or do i run one wire to the left light then carry it on from the left light accross to the right light?
each will have seperate earths so no problem there, its just the feeds im getting confused about!
Locoboy
worX
posted on 14/2/07 at 03:09 PM Reply With Quote
I've run TWO lots of wires down the left side.
Which were actually just elongations of the Blade loom.
Apart from the sidelight wire - that was a single, so I did "Y" that at the front...
RazMan
posted on 14/2/07 at 03:10 PM Reply With Quote
Separate feeds and earths are the order of the day. Ideally these need to be right back to the fusebox, even on separate circuits but not essential.
Remember the current for EACH headlight will be up to 5 amps so make sure that if you tee them together at any point, the wiring is capable of carrying at least 10amps (15amps is even better)
HTH
Raz
posted on 14/2/07 at 03:14 PM Reply With Quote
To extend what Raz said - it's worth having a separate fuse for each headlight circuit so that you don't go blind when your fuse blows on a dark night. I have 4 headlight fuses L & R dip, L & R main.
I also have 1 fuse for the left sidelights, and another for the righ-hand ones.
Not compulsory, but seemed like a good idea.
posted on 14/2/07 at 03:20 PM Reply With Quote
separate circuits are better (not sure what SVA state - I doubt they are able to determine one way or the other) becasue if one fuse or wire fails, you still have the other headlamp working - could make a big difference if driving a night.
arrggghh, orang-utan beat me to it
[Edited on 14/2/07 by 02GF74]
macnab
posted on 14/2/07 at 03:24 PM Reply With Quote
hmm I would have used just one coming from a switching relay (one relay for main and another for dip) and a take a feed from the other light at the first lights connector. After all if the fuse went you can just switch to the working circuit. I like to keep the electrics as simple as possable since there's less to go wrong then and I use quite thick cables and soldered connections with heatshrink plus loads of tie wraps.
[Edited on 14/2/07 by macnab]
locoboy
posted on 14/2/07 at 03:26 PM Reply With Quote
I am using the r1 loom which all runs off the same fuse, so no choice there.
just need to know whether to Y the feed or to link from one light to the other?
Locoboy
macnab
posted on 14/2/07 at 03:30 PM Reply With Quote
no right or wrong way you'll just have to choose complicated or easy
posted on 14/2/07 at 03:31 PM Reply With Quote
If it were me, I do whichever results is shortest (less weight) of wire so probably Y?
RazMan
In which case wire both lights back to the Y split but make sure the wire is man enough for the job - some bikes had low wattage headlights as standard and plonking a 60/55W halogen light on the standard wiring could result in a fried loom (or car)
[Edited on 14-2-07 by RazMan]
Raz
macnab
posted on 14/2/07 at 03:54 PM Reply With Quote
a lot depends also on the quality of the wire as some cables that look thick are of such low grade that it is easy to over rate them. The wiring in my blue birds is so thin you'd expect half the wiring could run just a courtesy light, but must just be of good quality. I also have special wire for offshore sond tools, it can handle 30amps but the wire is 0.8mm thick! and is silicon covered, to good to use in a car though.
miegru
posted on 14/2/07 at 05:15 PM Reply With Quote
When I did my car the guy at the carelectics cmpany who sold me the cables and stuff advised me to keep splits and connections in the loom to a minimum. Reason being that in a loom it is very difficult to keep moisture out plus the fact that most connections in a loom reduce flexibility; increasing the chance of breakage and sodiering cutting into other wires. Sounded reasonable to me.
So I tried to make the connections at the plug: in the lights. There it is closed of from the elements. And if there is a problem it is easier to repair than something inside a loom.
On the how many fuses discussion; I was planning on using a separate fuse for each light like somebody else mentioned. The above mentioned guy talked me out of it; he told me to keep it as simple as possible.
If I would do it again I would probably simpify the loom by making a separate fuse and relay box in the front. Only one powercable and a few very thin relay cables to route. Should save some weight. Same with the back-end. I was amazed at the weight of the wiring loom!
Rgrds,
Mies.
iank
posted on 14/2/07 at 05:52 PM Reply With Quote
Sounds like the bluebird uses modern thinwall cable. That super thin high current cable sounds like some stuff I used years ago, was told the covering was ptfe. Boss was too cheap to buy the proper strippers so it was like using your teeth on regular mains cable.
Anonymous
flak monkey
posted on 14/2/07 at 06:10 PM Reply With Quote
My loom is wired with the dipped and main beams on a seperate fuse. There is a single main feed for each from the switch to the fuse box. Then two wires run from the fuse box to each light individually. The headlights are the biggest *constant* draw on the cars electrical system in a locost (10A for the pair), next being an electric fan. Use decent wire (16A rated) and you cant go far wrong.
Sera
http://www.motosera.com
