Paradoxia0
| posted on 19/2/07 at 01:48 PM |
Oil pressure switch connectors
Hi Guys
As you can probably guess I am into the lovely job of connecting all those lose ends of wires onto the appropriate parts in my engine bay...
The next issue I could do with some help on is the oil pressure sensor.
Currently I have 2 wires from my luego loom that are labelled "Oil pressure sender" and "Oil pressure switch". I also have a
facet fuel pump that states that it should be fed form the oil pressure switches "P" terminal.
On my Rover V8 engine I can see the 3 prong oil pressure switch and another device next to it that has a 1 prong connector.
Can anyone let me know what each of the pins are for and therefore what should be plugged onto them?
I can attach a photo later if it helps?
Thanks in advance.
Mark
There is no replacement for displacement...
Paradoxia0
| posted on 19/2/07 at 11:05 PM |
Picture as promised earlier...
If anyone could let me know what should connect to each pin I would appreciate it.
Mark
