| posted on 1/3/07 at 09:01 AM |
electronic speedo
qucik question; I believe these work by having a stepper motor move a pointer so if you turn of the ignition and the car is not stationary, I assume
the pointer will not be a 0 mph?
So when you power up, does the pointer move to repositioning itself to 0 mph?
tks
| posted on 1/3/07 at 09:20 AM |
wait
you say a couple of things....
reset is always done by a fixed point in your case it would be a pot meter connected to the shaft ( i guess)
wich will tell you where the 0 is... where the 30 is etc. etc..
ot just only the 0 and x steps per km/h..
in this case its easy for the clock to reset it self and after reset it could start listening to the speed sensor.
in case you have a different speedo it wouldn´t be a problem to because knowing its in the down position (below 0)
it will know the offset to 0 + steps per km/h sow it will remark the correct speed....
there is only one excemtpion and thats when you cut off and directly turnon, then it could be marking 0 and readd the 0 offset.. thats the reason i
prefer the potmeter tactics... also if your sensor goes out on higher speed you could recompensate easyer...
Tks
| posted on 1/3/07 at 12:32 PM |
AFAIK only the posh ones (e.g. Stack) use stepper motors, the electronic car speedos I have seen use a simmilar movement to an electronic tacho, i.e.
moving coil meter. In fact you could use a tacho as a speedo if you could get the correct pulse rate into it.
