Chenti
| posted on 14/3/07 at 09:35 PM |
security
I have removed my steering lock and now need to make a nice job of securing the car without having the horrible sierra part in the car
What do you think of these?
TOAD STERLING TOUCH KEY Thatcham CAT 2 IMMOBILISER
30 notes off ebay
Or what do you do?
thanks
flak monkey
| posted on 14/3/07 at 09:37 PM |
I just bought something similar. Seems ok. Was having a play around with it earlier. Simple to wire in, and will count as another anti-theft
device.
Sera
http://www.motosera.com
nitram38
| posted on 14/3/07 at 10:50 PM |
Got one on my car. Impossible to start without the chipped fob.
PeterW
| posted on 14/3/07 at 11:53 PM |
OK...
I've read the SVA manual, and I'm still none the wiser...
What is meant by 2 forms of immobilisation..? The manual states'in addition to the ignition switch...' but what happens if you dispense
with the switch..?
Would a keyless immobiliser plus a normal switch for ignition, then a start button, pass the criteria..?
Pete
nitram38
| posted on 15/3/07 at 12:02 AM |
You can have an fia key as one and an ignition switch as the other or a mechanical form of security like a steering lock.
On mine I have an fia switch with toad immobiliser plus a seperate start switch.
The fia switch is one and the immobiliser is the other on mine.
My steering wheel is also removeable but this did not matter.
flak monkey
| posted on 15/3/07 at 07:37 AM |
Mine will be an ignition switch with the immobiliser as the second. I have removed the ignition barrel and switch from the column.
Sera
nitram38
| posted on 15/3/07 at 07:50 AM |
I don't like steering locks, they are dangerous !!!!!!!!!!
flak monkey
| posted on 15/3/07 at 08:16 AM |
Thats why i removed mine
Sera
westcost1
| posted on 20/3/07 at 12:34 PM |
why is the steering lock dangerous? duck and cover
iank
| posted on 20/3/07 at 12:49 PM |
Well a steering lock is only dangerous if it fails and locks while you are driving. Losing steering is arguably the worst mechanical failure that can
happen, worse even than complete brake loss.
Guess it's a risk of failure vs. consequences of failure decision you have to make for yourself.
Anonymous
nitram38
| posted on 20/3/07 at 01:12 PM |
After using a secondhand colomn that could be 10 years old, /i would go with removing the lock
