Author: Subject: wiring diagram
oadamo
posted on 27/3/07 at 05:48 PM Reply With Quote
wiring diagram
hi has anyone got a wiring diagram for a locost for all the lights and heater or is it easyer to use a car wiring loom thanks adam
big_wasa
posted on 27/3/07 at 06:38 PM Reply With Quote
A scratch built loom will be custom made to your own spec. Working on mine at the min. Treat every circuit as a seperate project.
Loads of info on here. This is the standard Sierra switch gear running the indicators and the hazards.
I stripped the sierra loom and filled two carrier bags full of usable wire and another two full of rubish.
tks
posted on 27/3/07 at 07:15 PM Reply With Quote
mhhh
the best is to make a list
and split up the car in 3 sections
Front
Midle
Back
to the Front you will need to put a tube with wire
to the back to
sow firstly just create a list with how many wires you need to trow to the front
and how many to the rear.
if thats sorted you already have 60% of the loom done
Tks
snowy2
posted on 29/3/07 at 09:04 PM Reply With Quote
wiring loom from scratch
Hi every one i have wired several kicars and specials in the recent past, its realy not hard to do, an article on how to do so is now posted on www.locostcarclub.co.uk . yup i know not this site sorry.
hearbear
posted on 30/3/07 at 08:05 AM Reply With Quote
Just make sure you run extra earth wires as this is probabily the biggest failing with a kitcar.
3.9Ltr SSC Stylus should be fun
