Steve Lovelock
| posted on 1/4/07 at 02:35 PM |
Vicki Green & MSnS - white wire questions
I am using a Vicki Green loom and an MSnS system. I am half way through sorting the wiring out and have a question regarding the two white wires that
are meant to power the ecu on the ford ignition system that comes with the pinto. Now as I am not doing that can I just ignore these wires?
bug1
| posted on 1/4/07 at 03:42 PM |
Hi I used the vicki green loom and I didn't use them a 12v feed to the relays then to the ecu is fine I did use the original ford engine loom
though but the ecu should only need 12v.
