Author: Subject: Flasher unit
locoboy
posted on 3/4/07 at 02:41 PM Reply With Quote
Flasher unit
I am using the R1 loom in my build, What flasher unit should i use seeing as i am going to have to graft in 2 extra side repeaters and hazards?
Or will the R1 one do the job?
Locoboy
RazMan
posted on 3/4/07 at 02:59 PM Reply With Quote
As long as each side doesn't go above 50 Watts you should be ok with the standard flasher.
Raz
mackei23b
posted on 3/4/07 at 03:44 PM Reply With Quote
I've used a ZX9R flasher with that set up and all is fine
Ian
