Simon
| posted on 28/7/03 at 08:53 AM |
Ignition Switch Wiring (Sierra)
Chaps,
I'm designing a loom based on a Mini diagram, having dismantled the Sierra loom for wire.
I am however using the Sierra column and ig switch.
Can't figure out wiring diagram from Haynes for Sierra, so do any of you know what the 4 wires from back of (Sierra ignition) switch do?
Thanks very much
Simon
| posted on 28/7/03 at 01:42 PM |
I'm not sure exactly but its something like one live, one for the starter (relay?) and of the other two, one powers stuff thats on with the
engine (ie the engine.. and stuff maybe including cig lighter, full beam etc.). The last one is probs for the first click of the ignition, stuff like
radio...
I'm rushing the loom out of my sierra cos the neighbours are moaning...
ned
| posted on 28/7/03 at 01:46 PM |
well, not 100% on this as manual is at home, but must be a live feed, earth, switched live (when key turns) and 1 other....
Ned.
beware, I've got yellow skin
| posted on 28/7/03 at 10:04 PM |
live in
ignition switched feed blk/yellow
cranking feed to ignition relay blk/blue
live out.
I can have a closer look tomorrow to check but you should be able to tell with a multimeter what does what when you turn the key.
yours, Pete.
