Author: Subject: Which Soldering Iron
Blackbird Rush
posted on 17/4/07 at 03:36 PM Reply With Quote
Can anyone recommend a suitable soldering iron for circuit board work (i.e. building a megasquirt), don't really need new and happy to get of flebay etc...
I have a gas powered one but i guess this would be too hot?
Ash
posted on 17/4/07 at 03:52 PM Reply With Quote
go to maplins, Antex 15 W is what I use. Set you badck all of £ 14.99.
TGR-ECOSSE
posted on 17/4/07 at 04:00 PM Reply With Quote
Best to go for a proffesional one if you can get it. I use Metcal or Pace ones. Will you be using lead free solder?
Fatgadget
posted on 17/4/07 at 04:23 PM Reply With Quote
I can recommend 3 types.
Weller, Weller and Weller!
I have heard good things about Hakko and the numerous Chinese clones they have spawned but I can't comment from practical experience.
stevec
posted on 17/4/07 at 04:25 PM Reply With Quote
I agree with Weller.
Steve.
[Edited on 17/4/07 by stevec]
iank
posted on 17/4/07 at 05:01 PM Reply With Quote
Metcal irons are really nice if you can afford them, much better than the weller one's I've used. But for through hole work you don't need that level of performance and weller are easily good enough and a much better price, if you're ever doing surface mount rework under a microscope though...
Did someone mention lead-free solder? <shudder>
Anonymous
smart51
posted on 17/4/07 at 05:27 PM Reply With Quote
15W is probably not enough from my experiance. It will do the job but it will struggle to heat things up meaning you'll have the tip of the iron on componenets for longer than is really good for them. Especially with some lead free solders.
TGR-ECOSSE
posted on 17/4/07 at 05:33 PM Reply With Quote
Been using it today takes a bit of getting used to Did you know tyre balance weights have to be lead free now?
Blackbird Rush
posted on 17/4/07 at 09:28 PM Reply With Quote
Cheers Chaps,
Had seen some weller ones and that seams the favorite, another question.......
Soldering station or just plug in the wall iron??
Ash.
posted on 18/4/07 at 09:33 AM Reply With Quote
hmmm, never had any components fail when soldered with my 15 W iron, seems to work alright for me
another tip - hold the iron by the cold end
