Author: Subject: P-Clips
kj
posted on 18/4/07 at 06:00 PM Reply With Quote
P-Clips
Do p-clips need to be rubber coated? the reason is i have some galvinised band from work which you can get from screw fix, it's like the stuff from car builders solutions only with out the plastic coating.
It WILL NOT RUST AND EVEN IF YOU BUY IT ITS ONLY £2.83 A 10MTR ROLL.
Thanks.
StevieB
posted on 18/4/07 at 06:25 PM Reply With Quote
I think so, though it'd be fairly easy to get some rubber channel the right width, but by the time you've messed about, you might as well have bought some.
graememk
posted on 18/4/07 at 07:11 PM Reply With Quote
i've just past sva and all mine are black plastic nylon type
RazMan
posted on 18/4/07 at 09:58 PM Reply With Quote
What about where you cut it? Go for plastic - that definitely won't rust
Raz
posted on 18/4/07 at 09:59 PM Reply With Quote
Cut some nylon or plastic pipe to the width of your clip and slit the side to go round your pipe then put the clip round it.
