myeates
| posted on 23/4/07 at 04:25 PM |
help anyone where do i connect hazard switched supply
hi guys i have a 7 pin hazard switch instead of the one on the sierra column.
the hazards work with the key turned off (as they should) but when i do this the hazard switch powers everything else so things like fuel pump start
running with the key off, i tracked this down to the fact i had the hazard switched feed coming from the same supply that other things are on so with
the power off and hazards on the switch was making a circuit to everthing else.
my switched supply is coming from one of the 4 wires on the ignition switch to the fuse box then split to things that need it. the permanent supply
comes from battery for hazards and side lights.
the key switch is a ford sierra one but so far i have only used 3 of the wires from the key switch, there is a yellow wire that i was told was an
axcillary power supply for things like radio would i power the hazards of this wire as it needs a completely separate circuit to everything else
any help will be greatfully received
[Edited on 23/4/07 by myeates]
| posted on 23/4/07 at 05:27 PM |
You could track the problem down... personally I'd just bung a power diode in there to stop the volts refluxing....
myeates
| posted on 23/4/07 at 07:40 PM |
just done quick diagram on paint the two wire in the bottom left box are the ones im questioning, this is how i have wired it up so far but do i
really need the + supply connected to the hazard switch aswel, as this is only really needed for the indicators
