DaveFJ
| posted on 30/5/07 at 11:03 AM |
Wiring frustration
Got really frustrated last night... merrily wiring in my instruments and switches to the tiger loom.
Naturally none of the connectors fitted my non-standard instruments or switch gear so cutting away and re-crimping and also adding wires where
neccessary.
Got to the last instrument and was having some difficulty identifying the wires so I got out the multimeter...
Just to find that I now have continuity between the Ign Live and earth!
Have started going through disconnecting everything in turn to see if it is the source but gave up in disgust after an hour and went for a
drink
Grrrrrr
I know - you can't help, I just have to work through it - Just wanted to vent my spleen....
[Edited on 30/5/07 by DaveFJ]
Dave
stevec
| posted on 30/5/07 at 11:22 AM |
Are you sure its a dead short and not just a resistance through something harmless.
Steve.
omega 24 v6
You will get a reading to earth through the ign live if it's connected to any device like a coil or motor or bulb etc. what you should be
worried about is what that reading is i.e. if its a dead short or just a combination of resistances.
DaveFJ
| posted on 30/5/07 at 11:28 AM |
I get a short to earth even with ignition off completely. Have disconnected every wire outside the 'cockpit' area so they are ruled out.
have disconnected every wire on the megasquirt and alarm....
so all that's left connected are the handbake switch, the light switches and the instruments....
I'm sure(hope) the fault will be obvious when seen through a fresh pair of eyes this evening...
Just worried that I may have cocked up somewhere when splicing in wires which are now buried in the loom somewhere...
Dave
| posted on 30/5/07 at 11:33 AM |
... probably a bit late now but I would suggest fitting one item at a time and testing it as you go along ... should you get a short at any time, then
it narrows it down to the last item wired.
don't be tempted by connecting a battery - the shorted wire will burn itself out but depending where it is, damage the loom in the process.
nitram38
| posted on 30/5/07 at 11:35 AM |
With a continuity check, any circuit will show as a "short" even if there is a correctly wired load on the end of it. You really need to
use an ohmeter as shorts will tend to show up as 0 ohms (or close to).
A little tip for testing you loom before connecting a battery is to buy a cheap battery charger and use that.
Obviously you can't test high power circuits, but you can check most things without risking high fault currents that a battery will supply.
flak monkey
| posted on 30/5/07 at 11:36 AM |
Oh dear, its always a pain to find a short, especially if you have wrapped the loom.
Just work methodically through each connector and see if you can find which wires are shorted in each one, this should narrow down the possibilities
somewhat.
My moneys on the lights as they can be an arse. Simple though the circuit may be.
Sera
http://www.motosera.com
omega 24 v6
But where are you metering?? is the coil still connected??
As you say sometimes it's better to walk away and look another day. It'll be a process of elimination as you say then. Have you got
various earth points on the chassis with everything going to them or just random earths?? if it's the first then try removing the earths until
the faults gone. It may be quicker than checking every feed wire. At least that way you'll know which leg of the loom it MAY be in i.e if you
remove the rear light earths and the shorts gone it's a better place to start looking.
Edited to say that you could be getting a reading through the h/brake warning light to the switch???
[Edited on 30/5/07 by omega 24 v6]
nib1980
| posted on 30/5/07 at 11:46 AM |
lucky you, I've been wiring up, and discovered that half the loom follows the french style, of all one colour black. 27 wires. all black.
i'm relying on luck at the minute!
DaveFJ
as I say - all lights / coil etc are disconnected.....
I am now thinking that maybe I have connected the intrument lighting circuit to the light switch incorrectly as the way it is now the lights on the
instruments will be permanently on (not that it would work I know but for the sake of argument)
Basically I am getting continuity across the +ve and -ve wires to the instrument lights and on to the chassis earth and also to the Ign live to the
instruments....
will check tonight to see what sort of resistances i am seeing. But first job is to rip out the light switch itself and see what happens (it was a
b*****d to fit!)
Dave
omega 24 v6
| posted on 30/5/07 at 11:54 AM |
Basically I am getting continuity across the +ve and -ve wires to the instrument lights and also to the Ign live to the instruments....
But you will as long as any of the bulbs are lef5t in situ or any other device that is connected to earth is left in this line or any line it's
connected to that has a device in it.
As an earlier post said you need to look at ohms and not have it on beeper.
A tip from me before you do start ripping thing to bits would be to fit an inline fuse to the main battery pos post and then to the main wire (in
series) then fit say a 10 amp fuse (no more) connect up and if it blows you've got a short. Don't try and start the motor and don't
turn on any other equipment other than the circuit you think the faults in.
DaveFJ
| posted on 30/5/07 at 11:59 AM |
so lights off and ignition off i should be able to measure contiuity from ignition live to earth? with NOTHING connected under the bonnet?
Oh bugger - just though about the Master cylinder fluid level detector.....
Dave
andrew.carwithen
| posted on 30/5/07 at 03:02 PM |
How have you got the fluid level wired in?
It should just be switched to earth on the -ve side of the warning light (same as handbrake switch.)
I.E -ve from warning lamp to one terminal and other terminal connected to earth.
NOT (as i've seen done) +ve to one terminal and -ve to other! (meaning a dead short unless filled with brake fluid!)
DaveFJ
| posted on 30/5/07 at 03:10 PM |
pretty sure I took a tap off the single wire that goes to the handbrake switch and ran that to the float switch then took the other terminal straight
to chassis earth - but I did that over 2 years ago so I can't be certain and now it's all hidden inside the loom somewhere...
Dave
andrew.carwithen
| posted on 30/5/07 at 03:21 PM |
Certainly sounds as though you've connected it up right. Is the reservoir filled with brake fluid? (otherwise, obviously, it'll be making
permanent contact - but not the dead short you're looking for.)
DaveFJ
| posted on 30/5/07 at 03:26 PM |
that was my thought before - cylinder is currently very low so it will be making contact......
do you have the Tiger 6fuse loom? if so do you know what the 2 black wires going to the speedo are for ? - they have different round type push on
connectors. I figure one must be earth but if the other is signal then where does the other end come out ?
Dave
Schrodinger
| posted on 30/5/07 at 03:41 PM |
Dave
My recolection of the Tiger loom is that the wires are for the illumination (standard speedo being mechanical)
I'm just off on holiday for a while or I would come and have a look at it with you.
Keith
Aviemore
DaveFJ
| posted on 30/5/07 at 03:43 PM |
I have another wire for the illumination (thin red same as other dial lights) so I think that's out. cheers anyway
Have a good holiday
Dave
andrew.carwithen
| posted on 30/5/07 at 05:49 PM |
Dave, mine is the 6 fuse loom, but as stated previously, the loom is for a mechanical speedo. I've looked at all the wiring diags and legends
I've got for the Tiger loom and they only show wiring for illumination (i.e red and black wires for +ve and -ve. - nothing for an electronic
speedo sensor)
Not much help, I know, but I've got the same two black wires with different sized female bullet connectors. However, as I intend using the bike
clocks, they are redundant for my use anyway. (I can only think, perhaps, that Tiger supplied two different mechanical speedos with different earth
connectors on the back?)
If you are fitting an electronic speedo then you should have the appropriate sender to go with it which, unfortunately, you'll have to wire in
yourself.
DaveFJ
| posted on 30/5/07 at 08:32 PM |
Well good news and bad news...
I have found the source of my problems
The switches that i bought at Stoneliegh seem to be .. knackered
Unfortunately they were from a stall where the bloke was flogging second hand parts recovered from the scrappy
plus side is they were cheap minus is they were the only ones I could find that I liked
On MUCH closer inspection they seem to have connectors missing and consequently I connected them wrong - connecting the negative for the switch
illumination to a terminal which was shorted to the main switch positive input
and, of course, I now have a hole in dash just the right size for these switches so i may just have to start all over
Here's a piccy of the switches I have - so if anyone can identify them I would be very grateful (oops apologies for the pic size!)
Dave
omega 24 v6
| posted on 30/5/07 at 10:15 PM |
Have you got a picture of the back of the switches???????
A lot of automotive switches are used to switch the earth side of a relay this could be what you're finding out with these. They look a nice
switch but I've not seen them before. How many terminals on the back of them??? Possibly the bottom slit illuminates as a tell tale to there
location and the symbol lights up when they are ON.
I don't know how UP you are on wiring and don't want to sound patronising but
If they are functioning then possibly they could still be used albeit with a bit of jiggery pokery and a relay. Don't give up yet unless
you're sure theyr'e fubared.
DaveFJ
| posted on 30/5/07 at 10:40 PM |
the main light switch has 5 terminals on the back like this:
I now find that the middle 2 are shorted together. the bottom left is side lights and bottom right is dip so the middle 2 I figure are for the
+ve...
the top one doesn't seem to connect to anything and the 2 lights inside don't come on no matter what combination of connections I attach
- however I know they work because I managed to ease the casing open and test then directly....
Dave
omega 24 v6
| posted on 30/5/07 at 10:51 PM |
Any numbers on the terminals or surrounds?? any makers ID??
Very difficult from a long way away to sort this one out
omega 24 v6
| posted on 30/5/07 at 11:11 PM |
Are these the switches????http://www.carlingtech.com/pdf/CarlingSW_V4_5.pdf
If you think they are then look at this.diagrams
DaveFJ
| posted on 31/5/07 at 07:49 AM |
WOW.. how did you find that??
yup these are definately the switches
Contura V....
now just got to decipher the diagrams etc to see what connectors should I have!
Cheers boyo
Dave
