Author: Subject: speedo magnets
ditchlewis
posted on 8/7/07 at 10:14 AM Reply With Quote
speedo magnets
what is the best glue to use to ensure the speedo magnets stay ahere they are supposed to.
can i wrap tape around tham with out affecting the speedo readings?.
ditch
DRC INDY 7
posted on 8/7/07 at 11:07 AM Reply With Quote
I used araldite and then wrapped it with heavy duty tape it does not effect the magnet or the readings
JoaoCaldeira
posted on 8/7/07 at 02:38 PM Reply With Quote
Ditto. Same here.
Readings are not affected if you keep within a safe distance.
Joao
ditchlewis
posted on 8/7/07 at 04:49 PM Reply With Quote
many thanks. i will glue and wrap. then set the sensor distance.
Ditch
