iceman26
posted on 29/7/07 at 08:12 PM |
suck or blow
ref fan
now i have your attention
do i need a fan that pushes or pulls it is going to be mounted in the nose cone
thanks
designer
| posted on 29/7/07 at 08:27 PM |
Is the fan electric?
In front or behind radiator?
jos
| posted on 29/7/07 at 08:50 PM |
it needs to flow the air through the radiator in the opposite direction to travel
it needs to flow air from the nose cone to the boot
so if you mount the fan infront of the rad it needs to blow
i fyou mount it behind it needs to suck
check sucking or blowing with a piece of tissue or light weight cloth
robertst
| posted on 29/7/07 at 08:52 PM |
and it doent really matter which you choose. their performance (cooling-wise) is more or less the same
Tom
