robertst
| posted on 9/8/07 at 02:14 AM |
VDO fuel sender hole size
i'm making the fuel tank and i want to have the hole for the sender made before i weld it up so i dont have to cut a hole later on when
it's all welded.
i looked around and found thet for a VDO sender you need a 43mm hole in the tank, but for a top mounted tube sender you need a 63mm hole...
does anyone have a side-mounted VDO sender and knows what size hole is on the tank?
should i just go for 43-45mm? i dont mind it being too large as i can compensate with the mounting disk later on.. what i do mind is it being too
small
cheers
Tom
robertst
| posted on 9/8/07 at 10:11 AM |
no one?
Tom
