graememk
| posted on 13/8/07 at 09:57 PM |
lower battery needed
i have a normal car battery in my indy and its to tall, i'm looking for something the same size but more "squot" lower, the width and
depth is fine.
and ideas ?
  graememkengine2
[Edited on 13/8/07 by graememk]
ned
| posted on 13/8/07 at 09:59 PM |
get a gel one, you can put them on their side, pricey but smaller and lighter and easier to fit.
Ned.
beware, I've got yellow skin
mookaloid
| posted on 13/8/07 at 10:12 PM |
depth is fine.
and ideas ?
  graememkengine2
Just having a look at that engine - it's a plumbers nightmare
Mark
graememk
| posted on 13/8/07 at 10:19 PM |
your right, however the reason for the new battery is because i've stripped the engine wiring and started a neeter job
Chippy
| posted on 13/8/07 at 10:32 PM |
Why not make up a tray, a couple of inches deep, and drop it into the panel, so the battery hangs down into the passenger footwell. Just thinking
lateraly. Cheers Ray
| posted on 13/8/07 at 10:37 PM |
quote: Originally posted by mangogrooveworkshop
Dont even try that one......gel ok on side no
I've seen lots of them mounted on their side? IN fact from Odysseys website it says "The ODYSSEY® battery may be installed in any
orientation except inverted without sacrificing any performance attributes"
saigonij
| posted on 14/8/07 at 07:16 AM |
A Ford Probe battery is very shallow because of the sloping nose.
i had a ford probe ( drag your minds out of the gutter ) and i can tell you that the only battery was a probe one, cause they are short!
expensive though..... cause only used on probes
v8kid
| posted on 14/8/07 at 10:18 AM |
I've got an Oddesy battery on its side and it spins a V8 no problem. There were quality control issues with another manufacturer.
speedyxjs
| posted on 14/8/07 at 02:29 PM |
The one from my donor xj40 was very small indeed. strange scince the one in my x300 is HUGE
