Author: Subject: Alternator voltage reulator
Pdlewis
posted on 5/9/07 at 06:49 AM Reply With Quote
I think the voltage regulator has gone on mme anlternator. under load it is reading over 17v accross the battery which also doesnt seem to be charging. is my thinking correct?
if so has anyone got one kicking arround or is it cheap to part ex for a recon?
Paul
posted on 5/9/07 at 07:35 AM Reply With Quote
Before doing anything clean, tighten and check your battery, alternator and earth connections.
fazerruss
posted on 5/9/07 at 07:50 AM Reply With Quote
if your regulator has gone post a picture of it cos my mum may have one to fit
Pdlewis
posted on 5/9/07 at 08:35 AM Reply With Quote
Will do if i can work out where it is. is there a way of testing it your self?
posted on 5/9/07 at 08:47 AM Reply With Quote
yes there is but I can't tell you since I don't have the book with me.
17 V is much too high - it will boil the battery dry, indicated by a smell of bad eggs.
what make/model alternator is it?
Pdlewis
posted on 6/9/07 at 11:31 AM Reply With Quote
I took it off last night and redid it all but didnt seem to do much. there is a small earth which goes into the plug on the rear of the unit is this enough or does it need an additional earth strap?
i changed from a steel bracket to an ali rs one this shouldnt make any difference should it?
The make and model are valor VA101
posted on 6/9/07 at 02:41 PM Reply With Quote
I doubt that is right.
Most likley to be Valeo; I believe a French company that reconditioned alternators. (although I could be wrong, they mmay have made theior own).
Most likely you have is a Lucas A 127; the valeo sticker is stuck on when it was reconned.
new regulator, ebay, £ 8
ofcourse if it is not, then ignore ^^^
Pdlewis
posted on 6/9/07 at 06:47 PM Reply With Quote
Looks very simlar i will take the plastic shell of the back of mine and see if it looks the same!!
Pdlewis
posted on 8/9/07 at 01:09 PM Reply With Quote
Took it to my local alternator place who tested its and said it was all ok but may have an intermittant fault. Got a recon for £30 and problems all solved
