dave1888
| posted on 9/9/07 at 12:59 PM |
MJ and tacho wiring
The wiring diagram for tacho shows the signal (S) should be connected to the negative side of the coil. When using megajolt should i connect the tacho
as the attached diagram, if so would i be right in thinking i take a diode from 10 and 12 on the edis unit to the zener diode.
| posted on 9/9/07 at 01:14 PM |
I used the tacho output from the MJ plug - it worked for me, sometimes doesn't work for others. This is with a Smiths/CA/Greengauges tacho.
Worth a try, before you make up the circuit you've described.
paulf
| posted on 9/9/07 at 07:50 PM |
It is also possible to connect the tacho to the PIP signal from the edis.
I found that the edis tacho output didnt work and used the diode method for a while but had a problem with that after a while.I then connected to the
PIP signal and found it to work ok.
Paul.
MkIndy7
| posted on 11/9/07 at 03:58 PM |
I've had to use this method on a friends Triumph Spitfire and i'm pretty sure its to blame for strange blips in the map, although the
internals of the guage also stick at times.
Quite often when watching the map whilst the car is running it will jump upto around 3,500 revs and its equivalent advance figure.. and then jump back
to where it should be in the map, causes a bit of a pop in the exhaust on the over run from a steady cruise but thats all.
So it does work but i'd try it as a last method. That was for a very old SMITHS Guage.
paulf
| posted on 11/9/07 at 07:48 PM |
That sounds as if it is picking up some interference on the tacho wiring and feeding it in as an extra pip signal.
Ive not had that problem but as suggested it may be best to try the other methods first.
Paul.
