ruudbeckers
| posted on 13/10/07 at 04:28 PM |
Will this pass SVA?
Mounted my fuel pressure regulator today. However, the connector for the injector will almost touch the fuel line going to the regulator and the cable
will also go over the fuel rail. Will this pass SVA?
  injector connector
ReMan
| posted on 13/10/07 at 04:39 PM |
I don't see why not, nothings going to move is it?
Put a bit of split sleeve over th coloured wires and you won't even notice it.
Avoneer
| posted on 13/10/07 at 05:08 PM |
Put some tube on the wires and a bit of split hose on the fabric pipe and it'll be fine.
Pat...
roadrunner
| posted on 13/10/07 at 06:54 PM |
It would fail if it where next to you exhaust manifold due to heat, yours will be fine.
