Mr Clive
| posted on 13/10/07 at 06:19 PM |
Savage switches - Waterproof?
I am wondering, is the front of the savage type switches water proof?
Im looking to build a car without any weather gear or wind screen. If I used them (sealed into the dash so water couldnt get to the back, only the
face) and they were subjected to a good downpour or two, would they survive?
bigrich
| posted on 13/10/07 at 06:33 PM |
the actual switch clips onto the rear of the aluminium face, the bit you see only contains the led illumination bulbs and contacts.
never had an issue with any of mine even when washed etc
Honestly don't think you would have any problems at all
Rich
Avoneer
| posted on 13/10/07 at 07:43 PM |
Hear hear.
Been out it the rain several times and mine still work.
Pat...
iiyama
| posted on 13/10/07 at 09:32 PM |
They do have an IP rating, but I forget what it is. Not much help I know, but the fact they have got an IP rating should tell you that they do have a
certain resistance to dust and water.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
RazMan
| posted on 13/10/07 at 11:03 PM |
Are you sure? I have several of these excellent switches and I can't see any evidence of any seals to prevent water ingress.
The electrical part of them is a microswitch which must be fairly resistant to water but the mechanical part is quite basic so I wouldn't depend
on it, but a few splashes shouldn't be too much of a problem imo.
[Edited on 13-10-07 by RazMan]
Raz
chockymonster
| posted on 13/10/07 at 11:10 PM |
Yep, they have an IP4x rating stamped on the side from memory.
martyn_16v
| posted on 13/10/07 at 11:32 PM |
IP forty-something isn't that waterproof, basically it'll resist ingress of boulders...
Mr Clive
| posted on 14/10/07 at 01:05 AM |
Thanks for the info, its good to know.
As long as they will survive the odd shower or two then they ok with me.
iiyama
| posted on 14/10/07 at 08:03 AM |
Im sure cause I asked the designer when I bought em!
looking at the rear of the switch I have to say that there is no evidence of any ingress prevention. The front is a differnet matter though, even a
rubber washer to seal to the dash.
Technically speaking I guess this wouldnt get a full IP rating in industry, Im pretty sure that for this the entire switch has to comply. However if
the back of the dash is reasonably sealed to the elements then the front of the switch looks like it will give reasonable protection to ingress.
I agree though that the rear of the switch looks like it might just stop boulder ingress!!!!
| posted on 14/10/07 at 11:25 AM |
iiyama... any IP rating can mean basically anything...
for a car dasboard which may be exposed to condensation and dust - IP64 would be adequate.
iiyama
| posted on 14/10/07 at 01:55 PM |
I realise that bud, looking at my post again I was a little vague....sorry bout that!
