joolsmi16
| posted on 22/10/07 at 07:57 PM |
polo thermo switch
My polo thermo switch has two spade connectors one larger than the other and Iam using a blackbird loom which only has one spade connector for its
thermo switch??
Question is what are the two connectors on the polos thermo switch and which one should I connect my single blackbird connector too!!??
mistergrumpy
| posted on 22/10/07 at 08:10 PM |
I think they're the two sides of some wax doohicky or a bi metallic switch or summat.
RazMan
| posted on 22/10/07 at 08:20 PM |
Both connectors are simply each side of the switch - just earth one side if the 'bird only requires one connection (switched to earth) It might
be a switched live though so check first.
Raz
Macbeast
| posted on 23/10/07 at 02:05 AM |
Don't some Polo thermal switches have two levels, say 90 deg and 95 deg ie cut in second fan or speed up fan once higher temperature is reached
Search polo fan switch, RichardK 23/9/07
Sorry don't know how to do linky thing.
[Edited on 23/10/07 by Macbeast]
