Simon
| posted on 20/12/07 at 09:06 PM |
Coil pack wiring?
Peeps
I've just bought a pair of coil packs V8, connectors, trigger wheel, sensor etc from trigger wheels
Does anyone have any idea how they are wired up.
I reckon the 4 big holes are for HT leads.
One I guess is signal, one for power.
I remember reading somewhere that they should (without additional input) allow the car to fire up and tick over, with a signal from ecu to
advance/retard spark. The trigger wheel has a tooth missing (I know it's supposed to ), so does this go at tdc on no 1? I take it the two coil
packs will fire a wasted spark and fire simultaneously (waffle waffle........) see my prob!
Cheers for any help - coil packs/fi are new to me so simple answers please
Emerald here tomorrow apparently
Simon
MkIndy7
| posted on 20/12/07 at 09:10 PM |
Here's a very good place to start:
http://www.extraefi.co.uk/drawings.htm
lsdweb
| posted on 21/12/07 at 07:21 AM |
Simon
The instructions that come with your Emerald will explain it all (or nearly all!). Their wiring diagram is very easy to understand and the
instructions on setting up the trigger wheel are also clear.
The instructions are on their web site if you can't wait for them to arrive.
Regards
Wyn
darrens
| posted on 26/12/07 at 11:13 AM |
If they're the same coil packs I bought from trigger wheels (ford) for my v8 then centre pin is +12v the other two are switch ground from your
ecu to trigger the coil. And as you say the four others are HT.
I have a photo somewhere of them installed on my engine, I'll try and find if you want a nosey.
