The Baron
| posted on 6/1/08 at 07:41 PM |
Testing a coil pack
I am having a real big clear out of stuff from my single garage so that I can get in it, to get my car out.
(I have found all sorts of redundant stuff!!!! about a million tie wraps, and so far I have 2 biscuit tins of mixed nuts, bolts, washers and pop
rivets to sort out)
The unusual thing I have found, is a coil pack from what I believe to be a ford CVH engine. (Don’t know why or when I got it!)
Does anyone know a how I can check if it works before I put on eBay?
Cheers in advance.
The Baron
| posted on 6/1/08 at 08:33 PM |
Attach 12v to the thick wires. Put tongue across the other terminals... Should tell you if it's working
omega 24 v6
| posted on 6/1/08 at 09:13 PM |
Simon
| posted on 7/1/08 at 01:48 AM |
See this, it may help:
http://www.v-8.org.uk/forum/viewtopic.php?t=2452
Simon
matt_claydon
| posted on 7/1/08 at 08:35 AM |
put spark plugs on the outputs, put 12v on the inputs. Briefly tap the ground wire to 0v and you should get a spark from all the plugs when you
disconnect the ground. The bodies of the plugs have to be grounded as well of course.
