Author: Subject: Pinto wiring - silly question
peterparsons
posted on 10/1/08 at 11:14 AM Reply With Quote
Hi All
It may seem a silly question but I dont do wires - give me a spanner and I'll fix it !
On a pinto Alternator, there are 3 wires - 2 red and 1 blue - where do they go to ?
does anyone have any simple wiring drawings I could borrow/Copy ?
Cheers !
posted on 10/1/08 at 11:20 AM Reply With Quote
IIRC the blue wire is the ignition light and the red wires are both +ve (you can twist them together).
posted on 10/1/08 at 11:25 AM Reply With Quote
I would tend to agree but wn't commit until I have seen a wiring diagram.
the lucas type alternator, wcih is most likely what the pinot had would have 3 tags:
two 6.8 mm tags that connect together hence you put the two red wires on there - two wires in case you are wondering to increasethe current carrying cpacity and the other wire goes to the smaller 4.7 mm tab and is for the ignition lamp.
