Pezza
posted on 11/1/08 at 03:59 PM |
What do I need?
Right lads and lasses.
It's time to get the wiring sorted on me Indy.
I have the sum of bugger all in the way of wire/terminals etc and am trying to make a list of what I need to buy.
Do I need different types of wire?
How much wire do you think i'll need (normal amount of lights etc, savage switches)
bullet or spader terminals?
Any recomendations would be apreciated so I can get everything ordered up at the same time to save on postage. Also any online stores people have used
would be a help.
Ben
[Edited on 11-1-08 by Pezza]
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
| posted on 11/1/08 at 04:52 PM |
VWP do wires in different guages, colours and tracer colours.
you will need battery cables - big fat wires.
nexdt wires for high curents - fronat lamps.
then thinner wire for indicators, fule pump etc.
so really 3 sizes of wire.
for commnections fo for spade, not bullet - more reliable.
also consider a multi way connector that you can wire entire dash ot rest of loom, then you can unplug and remove it by undoing 1 connector. locost
is to use a PC multiway connector but is time consuming making the connections.
conside using trailer wire - 7 core - for indicator/real lamps as you trail one cable insteda of having to keep a bunch of cables to fether.
then you need some sort of covering for the loom - convoluted tubing or sprial wrap - prefer the latter.
mookaloid
| posted on 11/1/08 at 04:55 PM |
Premi
er Wiring Loom
Pezza
| posted on 11/1/08 at 05:31 PM |
Cheers chaps.
Flasher relays: do I need 1 per indicator, or can 1 relay work for multiples? (1 per side say?)
Would 11 16.5 and 33amp thin wall cable be sufficient or do I need higher?
110 amp good for a bike battery?
Ben
