pewe
| posted on 15/1/08 at 03:27 PM |
Fuel pump cut-off switch
Just a thought for those with carbs.
Apart from wiring in an inertia switch I've also wired in a separate cut-off.
This means I can run the carb. dry after use reducing the likelehood of unleaded fuel gumming up the carb. if it isn't used very frequently.
I assume this isn't a good idea for injection systems due to priming issues.
Cheers, Pewe
| posted on 15/1/08 at 04:23 PM |
If you have used a Rover inertia switch you can pull the button up to cut it off.
If it's hidden away it makes a decent anti-theft device as well.
