kelloggs
| posted on 16/1/08 at 01:35 PM |
windscreen wiper motor wiring
Have just fitted new wiper motor 2 speed L/h park Wiring from motor 1 yellow 1 blue 1 red , Have got 2 speed working but is not parking, am I
something missing? any help & advice much apprieciated.
JAG
| posted on 16/1/08 at 01:50 PM |
Yes you are missing something. It has been discussed before so try a search.
I don't have the info' you need to hand - sorry.
Justin
| posted on 16/1/08 at 02:13 PM |
the something that is missing is that the motor has mechanism inside which result in a live wire until the wipers park.
this live needs t o go to the switch wchih in turn feed the motor with power. this allows the motor to be on long enough until it parks, even if you
open the switch.
that is how the land Rover ones work and I guess the principle is the same for other wiper motors.
Agriv8
| posted on 16/1/08 at 02:29 PM |
This should explain
SVC Linky
HTH
regards
Agriv8
| posted on 16/1/08 at 03:19 PM |
You should connect it so that when (and only when) the stalk or switch is at wipers off, the live park wire goes to the slow speed terminal. As
already mentioned, the park wire supplies the juice until the wipers are parked then the park wire switches off.
kelloggs
| posted on 16/1/08 at 07:20 PM |
wiper wiring
Thanks for your replies very much apprieciated Cheers
Bob C
| posted on 16/1/08 at 11:27 PM |
The wiper park switch does hold a trap for the unwary, it switches between 12V and deck so that the motor stops sharpish at the park position. So it
IS possible to wire it wrong in a way that blows fuses a lot......
I'm about to wire mine up & it looks as though the lucas 2speed motor connects nicely to the sierra stalks - anybody care to comment?
Bob
| posted on 17/1/08 at 02:27 PM |
it IS possible to wire it wrong in a way that blows fuses a lot......
tell me about it!!!
