Author: Subject: Fusebox
tks
posted on 5/2/08 at 06:35 PM Reply With Quote
Fusebox
Hi fellow builders...
i have brought some blade fuse boxes and was wondering if its allowed to
Join on 1 side all the inputs together....
and wire only one (4mm2) wire to the battery???
Tks
p.s. what about sva the joining will be visible
stuart_g
posted on 5/2/08 at 06:47 PM Reply With Quote
as long as the wire to the battery is protected by a fuse then I don't see why not.
tks
posted on 5/2/08 at 07:12 PM Reply With Quote
yupsz
the first fuse will be used for it...
Tks
