mistergrumpy
| posted on 17/2/08 at 08:50 PM |
Hazard Lights
I've done lots of searching on this so I know it's a re-occurring question and I've got some helpful stuff but I'm still stuck
on how to start. Basically I've got Sierra stalks with there plugs and wiring and I'm connecting to a ZX9 loom. I think I'm half
understanding but will I need some kind of hazard flasher relay or just a standard flasher relay from Halfords. I've an indicator relay already
on the loom can I use this in some way.
Cheers in advance. I know this is a common question.
big_wasa
| posted on 17/2/08 at 09:14 PM |
If you have the sierra switch and the sierra relay it will do the lot.
I split it out of the sierra loom and got it running with a perm +12v for tha hazards and a switched +12v for the indicators plus an earth.
mistergrumpy
| posted on 17/2/08 at 09:15 PM |
So I need a Sierra relay then? Is it called a flasher relay or a hazard relay?
big_wasa
| posted on 17/2/08 at 09:21 PM |
as found behind the dash on any sieera.
I can work out a wiring diagram if needed.
big_wasa
| posted on 17/2/08 at 09:26 PM |
Just read about the bike loom. That I can not help you with. But you could still use the sierra bits to do it instead if nobody gives you any other
ideas.
[Edited on 17/2/08 by big_wasa]
mistergrumpy
| posted on 17/2/08 at 09:28 PM |
No thats great mate. I got a good idea from a sketch in Steve Gustersons archive I should get it from there. Like I said I just didn't know
where to start really. Grateful for that mate. cheers
mackei23b
| posted on 17/2/08 at 10:02 PM |
I used the relay from the ZX9R loom, worked Ok for me.
Ian
big_wasa
| posted on 17/2/08 at 10:11 PM |
black is ignition switch live, red is perm live.
there are two wires that feed the bulbs Black/ white trace and Black/ green trace one is left and one is right.( I didnt check which was which).
All other colours as seen at the plugs.
very easy to splice into any loom.
Any help ?
the ford relay will need to see a load of 21W+21W + (side repeater)each side to run
