Chas
| posted on 6/4/08 at 12:13 PM |
'94 Fireblade RRR CDI/ECU
Incidentially, does anyone know how many pins my CDI unit should have? I have the part code MWO so should be a 94 item but bould like to check.
worX
| posted on 6/4/08 at 12:22 PM |
I read your other post, but couldn't help you as I don't know the later Blade looms, but luckily Andy did, but as a thought to your
general problem solving, have you considered getting an earlier Blade loom (at least for testing of your systems). You should be able to get one for
around £50, but if you really haven't got the money in your KC budget then thats fair enough, but my fear (if I was you) would be that one
problem leads onto another.
Which might end up costing you money.
If I were you I would buy a correct loom even if you are skint - get yours working/check all systems - and then sell it again. That way for the sake
of a little lost profit or postage (say £10 or so) you could of solved all your problems and checked things like extra wires in plugs and so on...
Please don't think I'm having a go - I hope it doesn't sound like that - I was just trying to see things and offer a more lateral
way off thinking!
Chas
| posted on 6/4/08 at 12:31 PM |
I was thinking about that, but there doesn't seem to be anymore looms of that year about at the moment. I was just a bit concerned about
Andy's comment on how there shouldn't be the pins in the CDI unit for extra wires, when mine has all 16 pins (MWO - '94 part code).
Thank you for the advice, didn't think you were having a go at all. Any information/suggestions are welcome in times of need.
worX
| posted on 6/4/08 at 12:34 PM |
I'll try and find out about a spare loom for you and send you a U2U if I have any luck.
It's a RRR model isn't it?
ETA - the first avenue I tried was no luck, but I'll find out tomorrow about the other...
[Edited on 6/4/08 by worX]
Chas
| posted on 6/4/08 at 12:41 PM |
You're a star. That would be invaluable. It's just the number of pins on the CDI that's confusing me now.
hector
| posted on 6/4/08 at 01:03 PM |
Hi have just taken some piccies of my 92 RRN fireblade cdi for you will post them in my photo archive for ya
cheers
hector
| posted on 6/4/08 at 01:12 PM |
As you can see in my pics in archive the plug only has 8 or 9 wires actually being used BUT the cdi unit has all the pins present, ps mine is the
early twin headlamp model 893cc, if you need any more info i also have a haynes manual if you want any info
cheers colin
Chas
| posted on 6/4/08 at 02:03 PM |
Thanks for that Colin. That's sorted that worry. Your CDI has a very close part code to mine too so I should be able to rely on that. Thank you
for your time and help, I owe you a pint.
