omega0684
| posted on 12/4/08 at 10:13 AM |
bank injectors for megasquirt wiring,
hi all,
i am currently wiring up my injectors to my megasquirt unit but im a little confused, the wiring diagram says that there are four wires coming from
the ecu, two of them are labelled up bank 1 injectors and the other two: bank 2 injectors. but the diagram does not say which cylinders are supposed
to be connected to either bank 1 or bank 2.
im running megasquirt 1v3 on a pinto engine with r1 throttle bodies.
megasuirt wiring diagram
any help let me know.
cheers
alex
graememk
| posted on 12/4/08 at 10:18 AM |
on my set up bank one goes to earth on injectors 1 and 2 and bank two goes to earth on injectors 3 and 4
hope that helps
omega0684
| posted on 12/4/08 at 10:48 AM |
is that for the pinto set up, or does it not matter, i have all the 12v wires linked so that they only need one 12v feed, is that ok, i would assume
that the the fuel is sprayed from the injector when the earth is made on on the earth side
[Edited on 12/4/08 by omega0684]
tks
| posted on 12/4/08 at 11:23 AM |
yupsz
for electronics its easyer(better performance) to switch ground then to switch positive....
thats the reason that it switches ground.
If you have bank fireing then the first 2 injectors of your fireingorder should be on BANK 1 and the other 2 on bank 2
Tks
matt_claydon
| posted on 12/4/08 at 02:23 PM |
It really doesn't matter as the injecton events are not synchronised with cylinder firing times any way. Some people do 1+2 and 3+4, I
personally did 1+4 and 2+3 as I felt it made more mechanical sense! As I said though, it really makes no odds.
All 12v connected together is correct, the earths are switched by the MS.
| posted on 13/4/08 at 06:09 PM |
You can select how many injection events you want per engine cycle, so they must be synchronous with valve events at least.
